E4OD speedo problem
Old Feb 26, 2005 | 12:57 PM
spsteve's Avatar
spsteve
E4OD speedo problem
All went well with replacing the E4OD in my 1991 F250 RWD 5.0 until it came time to connect the speedometer. My truck uses a cable and apparently the replacement transmission is a newer model that did not have the drive gear for the speedometer on the output shaft.
At this point I think I can live without the speedo but there is also a 2 wire sensor of some kind on the speedometer cable itself that seems to be reporting on the speedo cable movement.
Does this need to be connected to a sensor that goes into the speedo cable 'hole' on the new trans?
I have located a sensor that is supposedly for this purpose but I wonder is there is anything inside the trans to send the signal (reluctor?)
Any constructive suggestions will be greatly appreciated..
Old Feb 26, 2005 | 03:58 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards
Old Feb 28, 2005 | 06:43 PM
efi460's Avatar
efi460
The e4od needs vehicle speed input to the computer to work.
The later trucks used the rabs sensor on the dif.tone ring.
You may be able to use the rabs sensor instead of the speedo cable mounted one.
The above may not be true, just what I've read.
What I do know to be fact (because I'm in the middle of an e4od rebuild) is that if you want to change the output shaft to the early speedo drive one
the entire trans. must be gutted.
