89 351- pulled heads, installed new timing chain and sprockets, made sure everything went back together correctly, new wires installed correctly, piston on TDC compression, then rotor on #1 wire. Will not start!! I've got fuel in the rails, spark at the plugs. Sprayed either to make sure it wasnt fuel not going through injectors and FLAMES blew back out the throtle body. Got my eye brows, lashes and hair pretty good. What the heck is going on here?
please help
