Sponsored by: Real Truck
Timbrens
Old Feb 25, 2005 | 03:48 PM
mwpierson's Avatar
mwpierson
Timbrens
Hello there...
I just installed some Timbrens on my F250. But, because of my lift (3" block) I had to use two spacers to get them close to the bump stop. Unfortunately there is still about an inch and a half gap between the bottom of the timbren and the bump stop on the ford block.
What you guys think about switching the blocks around? Would putting the ford block on top of the 3" lift block cause any problems? If I could do this, I could remove the spacers all together and have the recommended 1" gap.
It looks like it can be done, the Ford block is flat on top and bottom. Unless, there's a key or something that centers the ford block on that pad that form-fits the axle.
Thoughts?
Thanks,
Mike
Old Feb 28, 2005 | 10:32 AM
mwpierson's Avatar
mwpierson
Bump... Any thoughts on this guys?
Thanks,
Mike
