Bronco II Ford Bronco II
feul pumps ...tank
Old Feb 24, 2005 | 08:04 PM
broncobilly86's Avatar
broncobilly86
feul pumps ...tank
Just a couple lil questions was just thinking it over with the below question on fuel pumps....So theres one in the tank on my 86 and then along the frame next from rear to front is the fuel filter right, lil canister small hockey puck looking one. Then a bit more up the frame is the second pump more by the inside of the drivers wheel...AM I RIGHT ....And did all BII's in 86 come with 23 gallon tanks. Thanks and have a good nite....
Old Feb 24, 2005 | 11:44 PM
Monty06's Avatar
Monty06
on 86's and some 87 you have a canister fuel filter by the rear.
for example my 87 has a front fuel filter.
onto pumps you have a low pressure intank pump and a high pressure inline pump
88-90 b2's don't know about rangers, only have 1 high pressure intank pump.
next question tanks all b2's came with a 23 gallon tank.
i have a 36gallon tank .
if your reading half full or empty or full all the time. either your voltage regulator behind your dash is busted or you have a faulty fuel sending unit and your floater is stuck.
