Sponsored by: Kumho
alighment problems
Old Feb 24, 2005 | 07:44 PM
shanesF150's Avatar
shanesF150
alighment problems
my trucks a 2wd 1995 F150
I did a alighment and is still turns one way
i put new radius arm bushings in.
then i checked out the tow and fixed it.
but it still pulls to the left.
its weard, is thare something about the truck that is maken it
do this?
Old Feb 27, 2005 | 07:53 AM
SRD4X4's Avatar
SRD4X4
Does the truck have a caster variation ?
Old Feb 27, 2005 | 10:05 AM
shanesF150's Avatar
shanesF150
i think yes
Old Feb 28, 2005 | 05:37 AM
SRD4X4's Avatar
SRD4X4
If you have less caster on the left,that could be your problem.Also too much possitive camber on the left or too much negative on the right can cause a pull to left.Could also be 1 of the front tires causing it too.What specs. do you have on it now?
Old Feb 28, 2005 | 02:15 PM
shanesF150's Avatar
shanesF150
i dident realy get into that i only did the tow.
My one side rubs my radius arm and i got stock tires. drivers
When the trucks lifted My drivers side tire is level but my other side
leans out. souldent thay both lean out when lifted off the ground ?
I usaly dont have time to mess with that but i dont no were to ajust it so
i kinda stay away from it
Old Feb 28, 2005 | 05:13 PM
SRD4X4's Avatar
SRD4X4
First thing to do is get it on an Alignment machine and see where it's set at now and go from there.
