do all 302's have the same hp potential?
Old Feb 24, 2005 | 07:21 PM
60tokick's Avatar
60tokick
I have a carbeurated 302 and was wondering if it had the same potential as all other 302's.
Old Feb 25, 2005 | 12:46 AM
85e150's Avatar
85e150
No.
Head, compression ratios, cams differ.
As for going down to the bare block, there are some Mexican cast blocks that are supposed to be better than the others, but let's forget that. Once you go to the bare block, you are pretty much able to build it to whatever you want, within the limits of a 302. If you are starting with and staying with smog-motor small-valve pinched exhaust heads, and low compression, you will be unable to get the power of someone bleeding the cash for the better parts.
You can certainly improve your motor's performance, but as old Shelby said, "There is no substitute for cubic inches except cubic dollars." He was referring to the difference between the rather crude 427's vs. the sophisticated Ferrari motors, but it holds true right on down to a Briggs and Stratton.
Ranger80
Jan 18, 2012 06:09 PM
Domestic_Nuwbee
16
Jun 23, 2010 05:11 AM
nflfreak43
15
Mar 14, 2010 08:12 PM
lesmore49
32
Feb 22, 2006 06:55 AM
