Locking the hubs
Old Feb 24, 2005 | 07:12 PM
vekrause's Avatar
vekrause
Locking the hubs
Hey all,
I've got a '91 ranger with locking hubs. I've always had auto hubs in the past, so I got a couple of questions. Can I leave the hubs locked and drive in 2 wheel drive? Will this cause problems later? (some roads are covered in snow, others aren't) Is there a special procedure for shifting in/out of 4wd? I was driving today in a couple inches of snow and it was hard turning in 4wd, any ideas?
Thanks
Old Feb 24, 2005 | 09:30 PM
rhilsbos's Avatar
rhilsbos
Locking the Hubs
On snowy roads, I like to leave my hubs locked in so I can easily shift into four wheel drive if footing gets iffy. Maybe needed it four or five times this year so far. Normally the truck handles just fine on icy/snowy roads (without added weight), but there is a suttle improvement going around turns on ice in four wheel.
Other than that, I make sure my hubs are in the "free" position. Leaving the hubs locked increases where and tear on the driving components of the front end, as well as the front driveshaft components and the transfer case - even in two wheel drive. It also reduces your mileage somewhat. I also prefer to keep my speed to 55 or 60 max with the hubs locked (hope that's not too fast) even on the interstate. Normally that is not a problem as I wouldn't want to go any faster when roads are slick anyway.
Rich
Old Feb 24, 2005 | 10:26 PM
hreed's Avatar
hreed
Where I live, the rule of thumb is "hubs in on Halloween; hubs out on Easter". I haven't had any problems driving my 83 or 95 Rangers that way for years. The front end is turning with the hubs locked, but about the only thing I have seen is a small drop in mileage.
Old Feb 24, 2005 | 11:41 PM
lurchy98's Avatar
lurchy98
I always have left hubs unlocked until I needed 4 wheel drive. They are so easy to lock and unlock it's worth unlocking them in 2 wheel drive to save on gas and wear and tear.
Old Feb 25, 2005 | 12:25 AM
reddog99's Avatar
reddog99
Originally Posted by vekrause
Hey all,
I've got a '91 ranger with locking hubs. I've always had auto hubs in the past, so I got a couple of questions. Can I leave the hubs locked and drive in 2 wheel drive? Will this cause problems later? (some roads are covered in snow, others aren't) Is there a special procedure for shifting in/out of 4wd? I was driving today in a couple inches of snow and it was hard turning in 4wd, any ideas? Thanks
You can leave the hubs locked if you want. The 2004 4WD Rangers don't even have locking/unlocking hubs, so they're "locked" all the time! To shift into 4WD, just be sure you aren't spinning at the time you shift. To get into low range, you should be stopped and in neutral.
If it's hard turning while in 4WD, then you either have too much traction to justify 4WD, or you may have a limited-slip differential in the front.
Pat
