400 pistons from the bottom?
Old Feb 23, 2005 | 11:39 PM
chapper's Avatar
chapper
Is it true that you can't pull 400 pistons from below? I'm doing my piston rod bearings this weekend and I may need to pull one rod for machining . . . .
Old Feb 24, 2005 | 01:37 AM
titanicf150's Avatar
titanicf150
Chapper
Yes it's true. You'll have to take the head off. Piston pin on the 400 is press fit to the rod so you can't even fudge the rod out the bottom leaving the piston up in the bore.
Ken
Torque1st's Avatar
Torque1st
Posting Legend
You must pull the pistons from above.
Old Feb 24, 2005 | 07:57 AM
MBDiagMan's Avatar
MBDiagMan
The only engine I can think of from which pistons are changed through the bottom is the old Offenhauser racing engine. It had no removable cylinder head.
Good luck,
Doc
Old Feb 24, 2005 | 09:23 PM
chapper's Avatar
chapper
Thanks everyone.
I guess it comes down to how out of round the rod and cap are . . . . if it's too bad: off with the head!
