Horsepower
How can I get the same horsepower and compression as the 1969 302 out of my 1973 302 and still have it look like a stock engine?
Thanks, I look forward to your replies.
Also, the lower CR made a difference, and a few other mods for emissions purposes.
All this stuff is internal except heads and intakes, if they are different. (sorry, can't tell you).
You can make a '69 clone easy. Just use '69 parts or equivalent, such as pistons, cam and the heads etc.
My reason for keeping it looking stock is I like the stock look. To me it is great to get great performing engine and everyone thinks you got all these aftermarket add ons and you raise your hood and you watch their jaw drop when they see a stock engine compartment. I would rather change the inside and get the horsepower and compression like the 69. Would a 66 Autolite 2100 2 barrell be a better carburetor than the current 73 2-V Motorcraft. I have a friend that put a stock cast iron 4-V intake with a Autolite 4100 and he did not notice much horsepower increase just more gasoline usage. Thanks
The bigger that number, the bigger the carb.
1.10 to 1.23 if I recall.
So, if you are running a 1.23 and your 66 carb is a 1.10 or any number small than what you have, save the carb gasket cost.
Somewhere here someone has posted the CFM for the Ford 2V carbs. All are well under 500 CFM. Seems to me a 302 can only suck in just under 400 CFM anyway, so without internal changes, cylinder heads to improve that number and a cam to make things happen, the change to a 4V results in what your buddy has...more gas, not much more pass.
Don't limit yourself with the stock look. Once you get the internals cooking, an aluminum intake and headers are almost a must.
For a totally stock look, keep the 2V, build the bottom end and valve train like you're going to run the Indy 500, and hide a nitrous set up in there for power.
