tailgate problems
Old Feb 23, 2005 | 06:01 PM
mike_94f250's Avatar
mike_94f250
tailgate problems
The tailgate on my '94 F250 doesnt open very easily. I have to really pull up on the latch release handle. Is it possible to adjust it, so that it opens easily? Or are there parts I can buy to make it work the right way?
Thanks....
Old Feb 23, 2005 | 06:08 PM
frdsforme's Avatar
frdsforme
I adjusted mine with the panel off the tailgate, there are 2 connecting rods. They pop out of the plastic clips and can be pulled inward. This worked for me.
Old Feb 23, 2005 | 06:25 PM
88n94's Avatar
88n94
Did you try lubricating the latching mechanisms and strikers and any other exposed parts?
Old Feb 23, 2005 | 06:51 PM
tex94F250's Avatar
tex94F250
Try lubrication from the inside with the access panel off. Also from each end with the spray tube attached. Check the clearance at each end and make sure that the bed hasn't closed up some. Does it seem to operate easily once open or is it hanging up a little?
Old Feb 23, 2005 | 06:52 PM
mike_94f250
No, haven't tried lubricating any of the exposed parts, dont think it would help. Appears to be an adjustment problem, like the wires or guides that connect the handle to the latches are stretched or out of adjustment. Thanks for the reply
