302 FI sensor question
Old Feb 23, 2005 | 05:40 PM
JetBlackBronco's Avatar
JetBlackBronco
Question 302 FI sensor question
i have a 91 bronco with a 302, and it is running rich lately, only getting about 10-13 mpg, and leaving excessive black soot in the taipipe. i just replaced the O2 sensor...im not sure that will fix it.
are there any other sensors that i can check/replace to make it run better?
Old Feb 24, 2005 | 09:00 AM
dbuck50's Avatar
dbuck50
try pulling the codes, that will tell you if any sensor is bad, or at least where to start looking. Had the same problem and it turned out to be my ECT (coolant temp sensor). BTW there are 2 sensors, one for the guage and one for the computer...the computer one is what can cause it to run rich like it is cold.
Old Feb 24, 2005 | 10:21 AM
Kemicalburns's Avatar
Kemicalburns
pull codes. a complete tune up wouldnt hurt either, check timing should be at 10* with spout connector removed. once this is all done disconnect your battery for about 15mins and then reconnect and drive for 30-45 mins. this allows the computer to relearn .
also pull the vacum line going into your FPR . if gas comes out then this to could be your problem.
late
Old Feb 24, 2005 | 09:59 PM
turboguy's Avatar
turboguy
what do you mean? pull the vacume line going to the FPR> (whats fpr? Feul pressure regulator?)
Old Feb 24, 2005 | 10:03 PM
JetBlackBronco
i pulled the codes, got: 179, 327, 328, 332, and 173. saying that the evp has an undervolt, and its running rich.
i gave it a tune up(plugs, wires, cap, rotor)2 months ago, and i was fine till about 3 weeks ago, started using more fuel and stuff. i replaced the EGR and now the O2...
ill have to test the EVP
Old Feb 25, 2005 | 08:55 AM
Kemicalburns
fpr fuel pressure regulator. if its bad, there is a vacum line running into the top of it and pulling it gas would come out. .
