intake swap?
Old Feb 23, 2005 | 09:02 AM
gman150's Avatar
gman150
intake swap?
ok, here's me dilema. I want to know if a performance intake manifold off of a mustang will work on my truck. If they're the same motor, then shoudn't everything fit together? A guy i work with has a chevy pick-up, with a 350 in it. He put a corvette tuned port fuel intjection intake on his truck and it's making me wonder if i could do something similar.
any input is greatly apprecieted and everything will be taken into consideration.
thanks guys,
Garrett
Old Feb 26, 2005 | 05:15 PM
LxMan1's Avatar
LxMan1
It will bolt up, but all of the attatchments will be in the wrong place. The throttlebody and sensors will be in a different location and will not hook up to the exsisting plumbing.
Old Feb 26, 2005 | 06:19 PM
Ted98's Avatar
Ted98
Plus the mustang intake would move your power band too far up, it would kill all the low end torque you need for moving a heavy truck.
Old Aug 14, 2005 | 08:47 PM
maddenusmc606's Avatar
maddenusmc606
I'm a little new to modular engines but what about it kills the low end torque?
Old Aug 14, 2005 | 09:03 PM
Ted98's Avatar
Ted98
The car intakes have shorter & larger intake runners designed for high RPM power. At low RPMs, the intake doesn't have very good velocity. But once RPMs start to build, the short/large runners flow well.
The truck intakes have longer & smaller runnners that maintain velocity at low RPM's. The problem is that at high RPMs, the longer/smaller runners don't flow as well and high RPM power suffers.
Some of the DOHC engines have multi-runner designs. At low RPMs, one set of runners feed the cylinders than at a certain point, butterflys open up and a different set of runners feed the engine at higher RPMs.
LxMan1's Avatar
LxMan1
Shorter intake runners mean less torque and higher rpm HP.
