Sponsored by: Auxito
Wiper Woes.
Old Feb 23, 2005 | 06:16 AM
Wizardvette's Avatar
Wizardvette
Wiper Woes.
I've had a problem with my wipers for awhile, and it now has aggravated me enough to post for a solution. They seem to decide not to wipe the entire windsheild every once in awhile. I tried to notice a pattern (warm weather/ cold weather) to no avail. I have tried re-bending the arm, also to no avail. If I push down on them, they will work fine, I'm guessing new springs will solve my issue? Anyone else with this problem? Thanks.
Old Feb 23, 2005 | 06:46 AM
mayhelm's Avatar
mayhelm
Hope we're talkin about a 97-03 F150 and not the vet here. Use a scew driver to pop the plastic cover off where the wiper arm attaches. Then just tighten the nut a little. Their made to slip so that ice are whatever won't damage any thing.
Old Feb 23, 2005 | 11:16 AM
Wizardvette
Indeed we're talking about the truck. I'll tighten the bolts a bit tonight and see if that works. I hope it's that simple, it has become annoying. Thanks for the info!
Old Feb 26, 2005 | 07:32 PM
Wizardvette
I should clarify the problem. The wipers are completing their entire pass along the windsheild, but they seem to be lifting from the windsheild while in motion. I can push down on them and clean the entire area, but when they are on without me helping them, they lift. I wonder if stronger springs would cure this.
Old Feb 27, 2005 | 06:40 PM
twtchy3's Avatar
twtchy3
If its weak arm springs you would notice that they get worse at higher speeds { lifting off windshield} Have you changed the blades?
Old Feb 27, 2005 | 07:26 PM
Wizardvette
Yes, blades are new. Second set actually. This problem occurs at speeds as well as sitting still. I am at a loss. There is no pattern. I could go outside tonight, and they'd work fine with washer fluid, but when I actually may need them they may miss a large portion of their path.
Old Feb 27, 2005 | 08:11 PM
fordman311's Avatar
fordman311
I notice that on mine it the blades miss the bottom right corner of windshield (passenger side). It's like the blade doesnt curl enough to get it. Normal...anything to fix?
Old Feb 27, 2005 | 08:27 PM
ccoram's Avatar
ccoram
I had the same problem - Replace both the wiper arms AND blades with Motorcraft arms and blades. You won't have any more problems.
