Sponsored by: Real Truck
speed recilbration
Old Feb 22, 2005 | 09:46 PM
ElectricBluesman's Avatar
ElectricBluesman
speed recilbration
Recently I have added the Hypertech tuner and a few other engine mods. The I lifted it and added 35 inch tires. Will the superlift Truspeed screwup my tuner? I cant imagine it will but would love to hear from someone who has done it. Thx guys
Old Feb 22, 2005 | 11:50 PM
DCSpecial's Avatar
DCSpecial
The Truspeed shouldn't effect your tuner. I have a truspeed and never had a problem with the chip I had.
Old Feb 22, 2005 | 11:56 PM
Gregsd250's Avatar
Gregsd250
nope, it don't change a thing... Except set your speedo back to the correct readings and i also noticed my shifting points were back to normal (what ever that is.) I used my GPS to set the calibration up on mine. the settings that came with the truspeed were off quite a bit. it seems they called for 6 turns... and it seems like it was like 12 or 13 turns for my trucks speedo to be accurate. i have the superchips programer and 4.30 LS diffy with 35's on mine if it makes any difference or not i'm not sure. i have mine accurate to about 1/10 of a mile in 30 miles. just take your time setting it up and one other thing set it up some place easy to get to until you have it dialed in. makes it easier to adjust as needed.
Old Feb 23, 2005 | 11:49 AM
Duksrule's Avatar
Duksrule
What truck do you have? I have an 03 4X4 6.0 and the truespeed screwed the computer up in the truck. Had it towed to ford and it was popping codes that they couldn't figure out. Took the fuse out of the truespeed and it has been fine every since. I couldn't believe that was the problem because the truck was fine after putting it in for about 5K miles. Then one morning it would start but if you put it in gear it would die. Called Superlift and they said that it wasn't for use on the 6.0 and that I should take it out. There was a $150 lesson learned.
Old Feb 23, 2005 | 02:10 PM
DougD's Avatar
DougD
It will actually help it in that your computer will be reading the correct speed to rpm which can affect the shifting and throtle response and kick in. I added Truspeed to my truck and LOVE it... I wish I would have done it sooner...
Old Mar 10, 2005 | 06:03 PM
mattd17's Avatar
mattd17
duksrule..... do you still have your tru-speed? i am looking for one.
Old Mar 13, 2005 | 07:27 PM
Duksrule's Avatar
Duksrule
Sure do. It is still in the truck with the fuse pulled out of it. Make me an offer if you are interested.
