power brake booster
Old Feb 22, 2005 | 07:30 PM
RICHMC54's Avatar
RICHMC54
Smile power brake booster
Im doing a frame off restoration on a 1968 f-100 short bed I have acses to a power assist unit in good shape (free) should I, Or should i not put it on? Does power assist make that big of a difference.
Old Feb 22, 2005 | 07:34 PM
lee's Avatar
lee
Hi and greetings from Gig Harbor neighbor!
Yup it makes a difference.
I believe you will also need to get a power brake proportioning valve.
My truck was converted when I bought it. Only complaint I have is the fit to the firewall needs some attention.
Good luck,
Lee
Old Feb 22, 2005 | 09:08 PM
460 Crew's Avatar
460 Crew
You'll be happy with the booster installed. The proportioning valve only needs to be changed if your swapping a disk conversion on. Power drums dosen't need a different one.
Old Feb 22, 2005 | 09:23 PM
RICHMC54's Avatar
RICHMC54
Question power brake booster
thanks My truck has original drums (all around) is it just a matter of bolting it on and connecting vacuum??????????
Lee when I am finished Iwill be parting out a 1968 half ton and a 19972 f-250 (ranger)
if you are looking for anything
