Wont fire
Old Feb 22, 2005 | 01:24 PM
thunderguns71's Avatar
thunderguns71
Wont fire
This might be a simple question, but if im getting fire to my plug wires and new plugs, and everything is timed right, why would it not fire/crank. Even when I pour gas in the carb. Any ideas?
Old Feb 22, 2005 | 02:29 PM
frty7ford's Avatar
frty7ford
no compression
Old Feb 22, 2005 | 05:41 PM
thunderguns71
Hmm why does this not surprise me, o well
Old Feb 22, 2005 | 07:10 PM
1968f100's Avatar
1968f100
there is a big difference between not firing and not cranking. which is it??
Old Feb 22, 2005 | 10:11 PM
thunderguns71
I mean it wont fire and run, sorry for the confusion. It spins fast, and I cant get it to tighten up any by moving the dizzy. All I got out of it today was one backfire through the carb.
Old Feb 23, 2005 | 09:30 AM
frty7ford's Avatar
frty7ford
An engine needs three thing to run gas spart applied at the right time and compression. If it was running fine before I would start at the timing again.
Old Feb 23, 2005 | 09:33 AM
Pkupman82's Avatar
Pkupman82
It sounds like a timing problem to me. Did you remove the distributor? If so it's possible you installed it with the timing 180 degrees off. I would start by making sure you have the number 1 cylinder at top dead center, verify that both valves are closed. Remove the dist. cap and make sure the point on the rotor is lined up with with the no. 1 plug wire
Old Feb 23, 2005 | 09:40 AM
Pkupman82's Avatar
Pkupman82
Sorry about that. If the point on the rotor doen't line up you may need to remove the dist. and reset it. The reason for the backfiring through the carburetor, is all timing...chances are it's advanced too far. What is happening is the spark plug fires before the intake valve closes all the way...this is what causes the backfiring condition.
Old Feb 23, 2005 | 11:01 AM
thunderguns71
Well it supposedly run before I got it, I had to put a cam lifters and gear set in it ,due to the fact the cam was worn down the the casting. When I installed it all I made sure it was on tdc and the marks on the set were aligned. I also replaced the head gasket because the guy who had it last said it had blown. I figured it might have been 180 off, but thats not the problem. Ive tried grounding the motor and made sure the rockers wasnt to tight, but I still cant get it to run. Replaced the points and rotor yesterday because it didnt have any spark, but it does know. It was electronic but has been converted to points.
Old Feb 23, 2005 | 11:20 AM
frty7ford's Avatar
frty7ford
I would grab a compression gague and see what it says. If good compression recheck the fireing order and the direction the dizzy is spining. I almost goofed that up last weekend (was looking at wiring the dizzy backwards) with my daughters turck, I had to get the book out. Remember it is reallly easy to get these distributors a couple teeth off and then they will not fire.
bass-n-fire
Dec 29, 2016 02:37 PM
luvbigtrucks
Feb 21, 2016 07:15 PM
Multipierce
Modular V8 (4.6L, 5.4L)
Oct 5, 2003 04:08 PM
rwoodfin
Jan 19, 2003 05:54 PM
mare
Electrical Systems/Wiring
Jul 25, 2001 08:43 PM
