Fuel Filter
Old Mar 31, 2005 | 08:47 AM
Roushians's Avatar
Roushians
hmm. I thought that I read somewhere that letting the engine run until it runs out of gas is bad for the engine?
Also, could one not use 2 vise-grips and pinch the gas line at both ends near the filter?
Old Mar 31, 2005 | 08:07 PM
tex94F250's Avatar
tex94F250
Well, I could use the vise-grips, trouble is that the steel tends to stay crushed once crushed. The Aikens Ford procedure is to trip the emergency cut-off and let the truck run out of gas, it just shuts off. A re-attempt at starting confirms no pressure. They have probably done thousands of fuel filters there, one of the largest truck dealerships anywhere. A diesel, however is a different animal due to the type of injector system and pump, NEVER let a diesel run "dry". $$$$$.
Old Mar 31, 2005 | 09:06 PM
quicklook2's Avatar
quicklook2
will this thread never end. just change the thing.
yes, no matter what you do some gas will get on you.
yes, you do need to relieve pressure.
yes, you do need a tool. this is a really easy job to do.
as nike says; just do it!
good luck and have a nice day.
Old Mar 31, 2005 | 10:04 PM
tex94F250's Avatar
tex94F250
SSTTP! Short, sweet, to the point, we're outta here!
Old Apr 1, 2005 | 08:44 AM
Roushians's Avatar
Roushians
I thought the fuel line was rubber? Is it a rubber insulated/covered steel line all the way from the tank to the engine?
Old Apr 1, 2005 | 09:39 AM
mike L's Avatar
mike L
Relax, are you having a bad or what??? Everyone has to start somewheres. He wants to make sure he doesn't break anything.
Ask all the questions you what. Get a Haynes manual is a very important repairs manual ( its cheap) it WILL make your life a lot easier, and save you some headaches. I like the step by step details these books have. Let us know how it went. Ps don't use a drop lite, a lot of people forget. The fuel may spray on the bulb. Then I guess this thread will end. :0 sorry
Old Apr 1, 2005 | 04:02 PM
soccerlawn's Avatar
soccerlawn
I already did change mine about a week ago, and yes I am surprised that this thread is still going, but chill out dude.
