what to do? a never ending question
Old 02-21-2005, 09:39 PM
powerstroked162's Avatar
powerstroked162
powerstroked162 is offline
alright so i got my 3" hypermax downpipe in sittin in front of my 5" SS straight pipe exhaust system, i threw in a 45 degree 4" elbow to a 4"inlet 9" long AFE clamp on universal filter from jegs,i installed my tri-pod pillar cluster gauges from hewitt, i have a new pcm with a superchips gold chip at the 80hp setting attatched to the pcm, i have a new heavy duty rebuilt auto tranny with luk clutchs and disks, heavy duty ats tourge convertor, i have a high flow fuel bowl assembly installed with the shimmed fpr mod done as well as the 10k mod. im runnin outta stuff to do and im still not satisfied with the power that this thing is makin. what can i do next? i mean i have done alot of tinkerin and mods to the ol' girl but i still cannot compete with any of the stock duramax's around here. so help me out fella's
Old 02-21-2005, 09:49 PM
ltfox's Avatar
ltfox
ltfox is offline
Injectors! Check out beansdieselperformance.com or get a set of baby swamps at swamp-donkey.biz that can get ya close to 300 +rwhp! Also a custom tuned chip!
Old 02-21-2005, 09:52 PM
ltfox's Avatar
ltfox
ltfox is offline
Also how about an intercooler to keep the egt's down and a bb turbo that will sing sweetly!
Old 02-22-2005, 09:40 PM
cangim's Avatar
cangim
cangim is offline
My thoughts are injectors as well, custom chip to your preferences as well.
Old 02-22-2005, 09:43 PM
ltfox's Avatar
ltfox
ltfox is offline
Ya can't tell what I've been dreaming about can you?????????? nah.................
Old 02-23-2005, 02:46 AM
powerstroked162
i've thought about doin an intercooler but i have had to do so much to work out turbo lag as it is without an intercooler and in the mind of a mechanic as myself and knowing how things work it would be a logical quess to assume that if your going to lengthin the amount of time it takes for air to reach the engine by routing it through an intercooler then it would make sense to believe your going to create lag...... right or wrong? i checked out that beans performance site and man there injectors are cheap! thinkin about buyin a set. one question though, if i put in injectors why would i need to plug in a custom chip instead of running with the superchip i have now? advance fuel curves to make up for new injectors i assume. let me know
Old 02-23-2005, 06:26 AM
ltfox's Avatar
ltfox
ltfox is offline
Your absolutely right about the inter cooler. Really the only time it will be a benefit is when ya have to have lower egt's. Your chip will work with new injectors. And it will most likely work pretty good. But to get the most out of them your truck will need the custom chip. Bean does sell chip/injector packages that gives ya a chip tuned for the new injectors. Talk to them at beans and they will help ya out.
OldWoodsDiesel
37
01-13-2020 11:53 PM
Millertime1388
1999 to 2016 Super Duty
07-24-2013 02:17 AM
Krazymaan
08-24-2011 06:53 AM
rowekmr
32
04-24-2008 07:17 AM
Quick Reply: what to do? a never ending question
