Are the frames different
Old Feb 21, 2005 | 06:20 PM
blue66tang95f150's Avatar
blue66tang95f150
Are the frames different between the f100 and 250 or is it just the running gear.
Old Feb 22, 2005 | 12:32 AM
Fomoko1's Avatar
Fomoko1
Not sure if the frame is different, the springs and axles will be heavier with 8 bolt wheels.
Old Feb 22, 2005 | 04:41 AM
jowilker's Avatar
jowilker
There is no noticable difference, in the frames. They can be interchanged.
John
Old Feb 22, 2005 | 02:01 PM
blue66tang95f150
Ok, i thought maybe they might be a little thicker or boxed.
Old Feb 22, 2005 | 02:21 PM
4xcrazy's Avatar
4xcrazy
the frames of a 250 are a little thicker judging by one I had. also check the spring towers they may be a little different. I know 350 frame is noticebly thicker and spring towers are taller to accept heavy rated coils. cabs &front clip can interchange. my 350 the only difference is the back cab mounts are on the outside of the frame rails instead of on the crossmember
