What is a stroker??
Old Feb 21, 2005 | 11:26 AM
Jason8705's Avatar
Jason8705
What is a stroker??
I know this may sound dumb but i was just looking around at some crate engines and some were strokers, what exatly is a stroker anyway??
Old Feb 21, 2005 | 11:53 AM
DesertDave's Avatar
DesertDave
A 'stroker' is an engine that has had the piston stroke increased over the original design specification. You know how displacement is boreXstroke? And how if you 'bore out' and engine block you increase it's displacement? Can also increase the stroke. It tends to be a little more complicated and pricey than a simple overbore, because you need longer connecting rods, usually different pistons and crankshaft, etc. Some custom blocks exist to allow big changes, both overbore and overstroke, to get over 500 CI out of a small block.
Increasing the stroke 'tends' to increase the low-end torque, and limits the redline due to the forces resulting from the increased stroke.
