Bronco II Ford Bronco II
#2 cyl miss
Old Feb 20, 2005 | 09:47 PM
wolfie64's Avatar
wolfie64
#2 cyl miss
89 BII 4wd #2 cyl miss ignition checked and good new plug wires, dist cap / rotor and plugs. want to know if you can help figure out if it is a fuel injector or valves. any suggestions would be a help.
Old Feb 20, 2005 | 11:13 PM
Monty06's Avatar
Monty06
first off welcome to FTE HI Monty here i would first pull the codes so you don't waste your money on buying part after part. if you don't know how to pull codes check out the b2 forum top of page reads tech article ken00's on how to pull codes.
Old Feb 21, 2005 | 12:17 AM
RomerB2's Avatar
RomerB2
Monty, are you the new greeter for the threads? I told Tim Lankin, that I wanted to do this, to get my posts up lol.
Old Feb 21, 2005 | 09:52 AM
mrshorty's Avatar
mrshorty
Out of curisoity, how are you isolating the fault to cylinder #2?
Fuel injectors are easy to hear, especially with a stethoscope, though that doesn't tell you if the injectors is clogged. Also, comparing the results of a cylinder balance test performed by removing spark plugs and a test performed by unplugging injectors might help isolate the fault to the fuel injectors.
I expect bad valves would show up during a compression check.
Old Feb 21, 2005 | 03:56 PM
wolfie64's Avatar
wolfie64
i HAVE NOT DONE A COMPRESSION CHECK YET. THE #2 PLUG IS THE ONLY PLUG THAT IS SHOWING NO FUEL TO IT AT LEAST THAT IS THE WAY IT LOOKS.I AM GETTING GOOD SPARK FROM IT. ALL THE OTHER PLUGS ARE BURNING GOOD AND THERE IS A TAP AT THE #2 CYL. I DO SUSPECT THAT IT IS VALVES BUT THOUGHT I WOULD ASK ABOUT IT MAYBE SOME ONE WOULD HAVE A BETTER IDEA. THIS IS NEW TO ME I AM USE TO WORKING ON THE OTHER'S ENGINES AND AM LOOKIN FOR ANY INPUT THAT IS FORD 2.9L SPECIFIC
