Sponsored by: Kumho
bigger wheels?
Old Feb 20, 2005 | 07:09 PM
hillbilly316's Avatar
hillbilly316
bigger wheels?
would it be too much of a jump to go from a 15 in rim to say something like a 17 or 18 inch rim.
I am not familiar with how backspacing causes issues, but if it helps the wheels will be going on a 96 F-150.
Old Feb 20, 2005 | 08:59 PM
SoCalDesertRider's Avatar
SoCalDesertRider
You can go with larger dia wheels no problem, as long as the backspacing is similar to the stock wheels and the tires you go with have shorter sidewalls so the overall tire diameter is similar to the stock tires. Stock tire dia is about 29". Too much backspacing can cause rubbing issues with suspension parts, like radius arms or leaf springs. Too little puts the tire too far out of the wheel well.
Old Feb 20, 2005 | 09:14 PM
hillbilly316
i will be lifting the truck and putting 35'' tires on it so how big could i go and how much difference can there be in the spacing before issues arise
Old Feb 20, 2005 | 09:50 PM
RawPower's Avatar
RawPower
You can go up to as large of a rim as you would like and as offered for a 35" tire. Im sure they have some 18" or 20" rim for some 35" tire, bu tI dont know.
The only problems that you could run into are long term axle problems, like premature bearing failure due to the added weight of the larger rims.
Old Feb 20, 2005 | 10:14 PM
hillbilly316
ok. thanks i have looked at wheels and i really like some of the weld racing evo wheels but they dont have any for a fifteen inch rim so thats why i was wondering.
Old Feb 21, 2005 | 10:19 AM
RawPower's Avatar
RawPower
Whoa, those are $760 for ONE 20" RIM. Yeah I wanted them too, til I saw the price.
They are tight though.
Old Feb 22, 2005 | 03:52 PM
hillbilly316
yeah thats the only problem, they are so expensive. so i don't know if i will be able to get them
Old Feb 22, 2005 | 06:34 PM
RawPower's Avatar
RawPower
Eagle Alloy's has some pretty sweet ones, so does Weld (non-EVO's). Eagle Alloy's are the cheapest too...
Old Feb 22, 2005 | 07:23 PM
hillbilly316
ok i'll check those out. thanks for your input
Old Feb 22, 2005 | 08:18 PM
hillbilly316
have been looking and was checking out roughcountry.com and was wanting to get some opinions on the Raider 480 composite wheels
Old Feb 22, 2005 | 08:21 PM
RawPower's Avatar
RawPower
No promlem.
I recommend getting an offroad mag and looking through it for rims, there are a lot in there and have a lot of pics.
Old Feb 22, 2005 | 08:26 PM
hillbilly316
sorry if i am getting annoying but i really like the big bullet hole wheels but everyone has them and i just want to have something other than what everyone has
Old Feb 22, 2005 | 08:37 PM
RawPower's Avatar
RawPower
Your not annoying at all...besides, Im bored most of the time, and if not bored-Im not here
Yeah, I agree. I have bullet hole factory rims (16.5") and like them, but want something like the EVO...but cheaper.
Old Feb 22, 2005 | 09:06 PM
hillbilly316
that seems to be the biggest problem for people on budgets and seeing stuff they really like and want but know they can't get it because they don't have the extra cash. once again thanks for all your help and advice.
Old Feb 22, 2005 | 09:19 PM
RawPower's Avatar
RawPower
Yeah, thats me. Budget limited, and I have to get 8-10", 40" tires, new rims, pinion roating shims, front/rear driveshafts, turbo parts, propane injection, hydro assist and shocks...I guess I dont have to, but I am...
