oil viscosity in 2001 5.4?
Old 02-20-2005, 06:51 PM
redrider65's Avatar
redrider65
redrider65 is offline
Just bought a 2001 f-150 with a 5.4 motor. the owners manual says to use
5w-20 oil in it. That sounds awful light to me, we have always used 10w-40 in our cars and light trucks. According to the sticker on the window, the previous owner used 10w-30.
So what weight should I use? Is there a reason to use 5w-20? I live in sw Missouri, so our temps vary from -10 to 110 degrees during the year.
Old 02-20-2005, 07:41 PM
superrangerman2002's Avatar
superrangerman2002
superrangerman2002 is offline
Welcome to FTE!!
IMO, you should use the 5w20 if it is under 100K mi, and then bump up to a 5w30 or 10w30.
10w40 is a bit heavy IMO, and not as shear stable as a 5w20 or 5w30. The modular motors don't respond well to weights higher than Xw30 and tend to have higher upper valve train wear.
This topic has been covered my times in the Oil and Lubrication Forums, you'll find lots of information on this very topic.
Old 02-20-2005, 10:55 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
I agree. These mod engines need oil to the top of the engine quick on start-ups and 5w-20 does well. I have towed 7000lbs with the a/c on in 98 degree weather and have had no oil related problems at all using Motorcraft 5w-20 with a Motorcraft filter.
perkis
1997 - 2003 F150
11-07-2020 10:00 PM
A_Freebird
Oil & Lubrication
13
01-04-2016 09:00 AM
hertfordnc
1997 - 2003 F150
19
05-17-2012 01:25 PM
DTS419
Oil & Lubrication
03-30-2006 10:15 AM
nationm
1997 - 2003 F150
16
01-27-2005 08:57 AM
Quick Reply: oil viscosity in 2001 5.4?
