dnutdave
Old Feb 20, 2005 | 02:07 PM
dnutdave's Avatar
dnutdave
dnutdave
I ran out of gas in my 79 e 100 351w auto , since then no power at all climbing inclines , i tuned it up , rebuilt carb , checked fuel tank and lines , everything seems o.k. . only other area is vacuum lines and engine electrics ie; vacuum modulators . if any one could help with a diagram or advice i would be very greatful . [ i miss having my van] Thanks Dave
Old Feb 20, 2005 | 03:45 PM
TheWiz427's Avatar
TheWiz427
Did you change the fuel filter? Alot of times when you run out of gas you draw wharever junk could be in the bottom of the tank and it will get caught in the filter.
Just my
Old Feb 20, 2005 | 05:29 PM
dnutdave's Avatar
dnutdave
checked fuel filter
a new fuel filter was installed with the carb rebuild, the the engine acts im stillthinking vacuum, it runs good ,excells good on level grond, as soon as i hit an incline it loses all momentum , i checked the tranny fluid , its good and not burnt
