Installing clutch linkage
Old Feb 20, 2005 | 12:28 AM
460f250's Avatar
460f250
I'm considering swapping cabs, putting an '78 automatic cab where I now have a 4 spd 4 x 4 cab. I'm thinking it will be a matter of installing the under dash clutch linkage from one to the other so I can keep the 4 spd. Can anyone confirm? I'm also assuming the floor pan will be the same from auto to 4 spd (haven't pulled the mats up yet). Here's hoping it's an easy swap.
Old Feb 20, 2005 | 01:09 AM
Mil1ion's Avatar
Mil1ion
Yes, you need to remove the whole pedal assembly & replace it with an auto set-up
Old Feb 20, 2005 | 01:22 AM
460f250's Avatar
460f250
Thanks. I wish the a/c would be as simple.
Old Feb 20, 2005 | 01:30 AM
oldhalftons's Avatar
oldhalftons
floor pans are the same, the transmission pan bolts to the floor.
swapping the pedal asseblies involves removing most of the dash.
Old Feb 20, 2005 | 11:32 AM
460f250's Avatar
460f250
Hmmm, the plot thickens. Is that the only way, or does it just make it much easier?
Old Feb 20, 2005 | 04:37 PM
Mil1ion's Avatar
Mil1ion
Here, let me help somemore
https://www.ford-trucks.com/user_gal...d=5727&width=0
Old Feb 21, 2005 | 12:13 AM
460f250's Avatar
460f250
Thanks, you da man.
I need to stick my head under the dash on both to compare. Something tells me I got a sore back coming up.
