Need Help
Old Feb 19, 2005 | 11:44 PM
rickherrera's Avatar
rickherrera
Red face Need Help
Does Anybody Know If It Is Hard To Change The Manifold Gasket.I HAVE A 93 FORD F-150 WITH THE BIG SIX.
Old Feb 20, 2005 | 12:03 AM
broncr's Avatar
broncr
Most people would say it is relatively "hard". Your '93 will be EFI, & I assume that may also make things harder. I substituted 6-7 studs for as many bolts, which made things a bit easier.
Hard? Yes. Impossible? Of course not...
Old Feb 20, 2005 | 12:05 AM
rickherrera
Thumbs up
THANKS ALOT broncr for the help
Old Feb 20, 2005 | 09:59 AM
NM5K's Avatar
NM5K
Don't know about the 93...But on my old engines, it's pretty simple.
The hard part on my type, is they are heavy! I installed mine on the engine stand, when I assembled the rebuilt engine. So it was a piece of cake there...But I'd dread having to do that in the truck...
Mainly cuz it's heavy, and you have to make sure everything is lined up, etc, while bent over the engine compartment...I'd probably have to climb in with the engine to be able to lift it into place...Hard to say about a 93...But probably similar... But otherwise, it's pretty simple... MK
Old Feb 20, 2005 | 10:14 AM
wickymustang's Avatar
wickymustang
Get a good buddy that works out a lot and take your time. Between the 2 of you no problem to line everything up and get it on. Torque everything how you should and no problems. Just don't think it will be an hour project and you will be fine.
Old Feb 20, 2005 | 08:45 PM
rickherrera
Talking
thnks u all for your replys ill try next weekend. i always try first and if i cant then it goes to the shop lol.
