I am in need of help, my driver side window has come off its track, and I'm having trouble getting the panel off to repair it. any pics or mechanical prints would be great. thanx
To remove your door panel do as follows:
1, Remove triangle sail panel from top of door (behind side mirror) This pulls out and up.
2, remove courtesy light lens from lower panel in door. (gently release tabs on top and bottom)
3 Remove window switch control panel ( tis pulls straight up)
4 Remove trim piece behind door handle ( pull interior door handle out and carefully pry bottom edge out and remove)
5 There are screws located behind sial panel, inside courtesy light, and in hole where window control goes. Remove these screws.
6 Lift door panel UP to releast the door clips. Then pull out carefully. Remove all plugs from left over accessories such as power mirror switch, and courtesy light. You should now have your door panel off and in your hand carefully set it aside and do what ou need to do.
Reassembly is in reverse order.
Hope this helps!
found these online if anyone wants them. from crutchfield, detailed pics on how to remove front and rear door panels. email me at michaelwebb74@hotmail for me to send them to you.
