Sponsored by: Auxito
quick question/need input
Old Feb 19, 2005 | 09:35 AM
ruger9's Avatar
ruger9
Question quick question/need input
Hi guy's. I am still trying to slove rough idle issue. It is getting worse.Went to mechanic(not ford).He said my truck probably needs "de carbed".They they clean carbon buildup from intake,egr etc.$69.00 Have any of you heard of this?what is your opinion? Can this be done myself? remember I am not mechanicly knowledgable.Thank You
Rich
Old Feb 19, 2005 | 10:47 AM
LxMan1's Avatar
LxMan1
Rich, it is possible, but their are other things to look at too. Is it giving any codes?
What exactly are you working on? Year, engine?
Old Feb 19, 2005 | 10:30 PM
ruger9's Avatar
ruger9
my truck is a 2002 f-150 with a 5.4 liter v8,4x4,auto transmision.I have also read posts about i.a.c. is it at the back of engine against firewall? any one have picts and/or detailed instructions?
Old Feb 19, 2005 | 10:33 PM
ruger9's Avatar
ruger9
Also no codes.Cleaned throttle body,maf,replaced air temp sensor,k&n air filter.please need help.
Old Feb 19, 2005 | 11:13 PM
broken wire's Avatar
broken wire
Is it only rough at an idle? If it is, I would be looking at the EGR valve for being opened up. If it is rough running down the road, has anyone check or cleared codes before posting, if they have cleared codes without telling you, to get a code now, it must go through a drive cycle to gather codes again, then I would suspect ignition coil failures.
Old Apr 1, 2005 | 03:04 PM
Scorpion_DvT's Avatar
Scorpion_DvT
Here's a shot...my buddie at work was having the same problems, took it to a mechanic and they found a vacuum line that was burnt through. Now that's as much as I know, he doesn't know where this hose is located, but it was replaced and his truck is running great now...maybe run this scenario to a couple of mechanics...good luck.
