1986 5.0L performance
Old Dec 25, 2001 | 10:54 PM
Bragsbe's Avatar
Bragsbe
Hey Guys,
I have a 1986 F-150 with a 5.0L EFI motor in it.
I am looking for some bolt on performance parts that wont break
the bank. I was thinking of a Cam, some headers (with the O2 port),
and a cat-back exhaust from summit. I want to have some good power but I would like to have decent gas mileage. What size Cam should I go with? Some company names and web sites would be nice if anyone knows any.
Thanks
Brian
Old Dec 26, 2001 | 06:57 PM
restorit's Avatar
restorit
Stay mild on the cam side. There's a book called "How to Build and Modify Ford Fuel-Injected 5.0-Liter Engines" by Tom Wilson that explains the in's and out's of modifying these engines. It's a good resource. Unless yours is a California model, you have the speed-density air/fuel metering system. Anything that will lower the idle vacuum past a given point will confuse the computer, and give you driveability problems. You can convert the truck to mass-air metering, which will allow more performance upgrades without throwing off the computer. The only drawback is that the conversion kits are pricey. With some know-how, you can rob a mass-air system from a junkyard donor, though, and save some money. Just some thoughts...... the performance mods are a good idea, but I would recommend researching your options to be sure that the engine's management system (computer) is going to like what you have planned, otherwise you may be disappointed.
Old Dec 27, 2001 | 08:35 AM
acbruno's Avatar
acbruno
