differential question
Old Feb 18, 2005 | 05:58 PM
Robert R's Avatar
Robert R
Hello I have a 82 f100 with a good differential.
I would like to install in 67 f100.
The one in the 67 is geared to low.
I would like to know if the 82 will fit.
Thanks for your help.
Old Feb 18, 2005 | 07:34 PM
ckf 71's Avatar
ckf 71
For One The 82' Is Wider Framed Than The 67' It Would Work If Relocate The Saddles But U Would Have To Change Ur Back Spacing On Ur Wheels Because The Rear End Is Also Wider From Backing Plate To Backing Plate, So If U Don't Want The Hassle Change The Third Menber And Cut The Cost And Labor
Old Feb 18, 2005 | 08:35 PM
Robert R's Avatar
Robert R
Thanks I will prob. do that.
I thought that if the 82 would fit i could swap axels and all.
Old Feb 18, 2005 | 11:03 PM
Fomoko1's Avatar
Fomoko1
After 72 the trucks were a little wider,
