Update on 10k mod
Old Feb 18, 2005 | 04:04 PM
Duane99's Avatar
Duane99
Smile Update on 10k mod
I did install the 10k mod today, but used the 5.6k resistor instead. Did not hook up a switch because this is just a try to see if I like it. It was impressive out on the road, you can sure tell the difference in it. Idle was just like everybody says (rough) it did increase my rpm's about 200 at idle and running 65 the same increase. At a stop with automatic trans it will light up the tires and that is with limited slip. It ran smooth with out any ses lights coming on. Overall I will keep it but will hook it up with the diode system and a switch also. This site is great but my wife is begining to not like it (LOL).
99 f-350 auto,swb,leveling kit, 4dr & 285 tires
Old Feb 18, 2005 | 04:37 PM
Turbo6's Avatar
Turbo6
Let us know if you milage increases. It probably won't because you're lighting up the tires!
Old Feb 18, 2005 | 04:44 PM
Duane99's Avatar
Duane99
LMAO that was just a guy being a guy, I really drive normal and dont pull very often. It will be a few days until I will get a good mileage update but will let you all know the results
