Transmition Dipstick
Old Feb 18, 2005 | 10:50 AM
sla3492's Avatar
sla3492
Sorry I have a stupid question and feel like a dork but. I have not owned a stick shift in 20yrs(WOW) and never a Ford (but I love it) til now. I looked all over where's the dipstick for the transmition on my 92 F250 7.3 5spd. And what type of fluid would you recommend.
Old Feb 18, 2005 | 11:15 AM
BOB ROSS's Avatar
BOB ROSS
found this one out the hard way myself, it has no trans. dipstick. check the fluid level at the fill plug on the side the trans. about half way up it on the drivers side. well... this is where it was on my 89 f350 7.3 5sp. hope this helps.
Old Feb 18, 2005 | 01:13 PM
PLC7.3's Avatar
PLC7.3
Check out this info go to the schematic.
http://www.zf-group.com/pdf/S5-42.pdf
Old Feb 21, 2005 | 10:31 AM
sla3492's Avatar
sla3492
Talking
Do u just unscrew the nut? Is there something on the other side to check the level and where do you put trans fluid in at? Does type does everyone recommend?
Old Feb 21, 2005 | 09:33 PM
PLC7.3's Avatar
PLC7.3
If you check the schematic you would see the fill hole above the drain hole, just fill it until it runs out then put the plug in. Synthetic Mercon ATF is recommended due to excellent cold temp lubrication and superior heat disipation.
Old Feb 22, 2005 | 10:26 AM
sla3492's Avatar
sla3492
[B]#22 & #29 are both labeled trans case plug is this it or which one is which?
Old Feb 22, 2005 | 11:34 PM
PLC7.3's Avatar
PLC7.3
Use the highest one to fill the lowest one to drain..........
Old Feb 23, 2005 | 11:53 AM
toyrobotus's Avatar
toyrobotus
Is that Mercon recommended for the 5-spd manual or can/should it be used in a 87 4-spd too? Any other recommendations for the tranny lube?
