Offroad & 4x4
Dana 60 wheels
Old Feb 17, 2005 | 08:15 PM
JD3220's Avatar
JD3220
Dana 60 wheels
Hi Guys
Since no one on the pick up fourm could answer my question, I thought I might find an answer here. I was given a 87 F-350 with Dana 60 axles but it has Budd wheels. Can this be converted to use a normal wheel?
Old Feb 17, 2005 | 08:45 PM
highboy1975's Avatar
highboy1975
im assuming that bud wheels are the wheels used on a dually. pardon my ignorance if im wrong. yes you can convert to use normal wheels although its not going to be all that simple. your going to have to change out the front spindle to a single wheel setup and change out the rear drum to a single wheel offset. you could use regular wheels on this truck, but they will stick way out. i should have probably researched what a bud wheel is, but im kina lazy ill do it later and im sure someone will be along to correct me if im wrong
Aaron-71
13
Nov 10, 2016 02:39 PM
augsburger
Oct 30, 2016 10:20 AM
mustang_gt_350
Jun 27, 2012 09:43 PM
zainman
Oct 31, 2007 07:10 AM
