Larger Fuel Tank
Larger Fuel Tank
I have a 95 F-150 Standard Cab Short Bed that only has the single rear 18 gal tank. I would like to get a larger tank. One day I was looking in a Trailer Life magazine and found an outfit "Transfer Flow" They offer a 31 gal and 45 gal Replacement Tank That supposidly comes with all mounting hardware sending unit ect. ect. There price is between $857 and $881. I was hoping for something not so pricy and/or see what else is out there. So far I have only found places that sell OE Replacements. Does anybody know where else I can look. And has anybody else done something like this and can tell me what kind of a job it is to replace a fuel tank. Transfer flow did mention there is a fuel line replacement tool had would have to get also.
JC Whitney sells larger replacement tanks for half that. Also the broncograveyard, and many other places.
If you search for "33 gal bronco" on e-bay you'll find a guy who sells new tanks for about $300 more or less.
The bronco tank will fit the F-series, however you may or may not have to relocate the spare tire. I got away with it with my crewcab, and I have a 33 gallon rear tank and the factory 19ish gallon side tank (which is leaving this spring also).
Changing the tank out isn't that big of a deal, its just awkward working under the truck. The strap bolts probably will snap, they always have for me whether servicing or replacing a tank. Stuff rusts, yanno? But do yourself a favor and run the tank almost empty (not completely empty as you don't want to have tank grit go into your fuel line), but gasoline weighs about 5lbs a gallon, so 10 gallons of gas in the tank is about 50lbs of additional weight above your face to shift around.
I take tanks out by cutting a 2x8 about the same length (or width) as the tank, putting a floor jack under that, then undoing the bolts. Once its all loose, I grab the 2x8 or the tank with gloved hands, and either my wife or a friend lets the jack down slowly so it doesn't slam on the ground.
Installation is the reverse.
desertnomad
6.7L Power Stroke Diesel
Apr 21, 2014 08:08 PM
austint513
40
Jan 17, 2014 07:32 PM
archer_ski
Nov 5, 2013 05:35 PM
