Noise
Old Feb 16, 2005 | 09:13 PM
albertafarmer's Avatar
albertafarmer
Question Noise
I have a 95 F-150 4X4, everytime I step on the brakes I get a noise(squeel) on my radio. Any suggestions.
Old Feb 16, 2005 | 11:04 PM
Franklin2's Avatar
Franklin2
With the engine off. and the key on acc, turn on the radio and hit the brake and see if it makes the noise.
Also, does it do with the tape or cd, or the radio only, am or fm?
Old Feb 16, 2005 | 11:42 PM
albertafarmer
Only on some AM stations, but all the time on my CB radio. Haven't tried it without the motor running, will try it next time I'm out there. I'm thinking its something to do with the ABS set up.
Old Feb 17, 2005 | 12:23 PM
Franklin2's Avatar
Franklin2
Ok, so it must not be coming over the dc 12 input to the radios. Do a little bit of testing, and if you figure out it's the alternator, or possibly some solenoids on the abs, I would check and clean the grounding to these components, and also check to see if you have the little silver metal capacitors hooked up. These look like little silver metal cans with one wire coming out. These are for noise suppression, and are usually mounted around the regulator, alternator, etc. If you zero in on the problem, you might want to get a few from the junkyard, and add them here and there to see if you can kill the interference.
