460 cam
Old Feb 16, 2005 | 09:10 PM
mshane's Avatar
mshane
460 cam
Hi everyone I'm new here. Seems like a great site. Anyway, I was wondering if you guys could help me decide between two cams for a 460. The cams are the Lunati 00096LK 214/224 .516/.543 and the Comp 4x4 xtreme 262, 218/226 .514/.524. The engine has edelbrock 95cc aluminum heads, speed pro pop up forged pistons, approx 10.3 compression, dui ignition, weiand stealth intake, edelbrock 1411 750 cfm carb. I was wondering which would make better torque, or if you guys have a better suggestion.
Oh yea, the tranny is a c6 with a 2000 stall.
Thanks a lot.
Old Feb 16, 2005 | 09:25 PM
Bubba Blue's Avatar
Bubba Blue
I am a big Comp Cams fan. Heard lots of good things about that cam. Can't get too techy without knowing what you expect from the vehicle in terms of usage, go fast, or pull hard kinda thing. How heavy is it, what is the final drive ratio? The Comp tech line does a good job of helping you to figure this out. 1-800- 999-0853 Been a while since I called, but I think that is still a good number. Caution: We are all tempted to go too big, we love the sound for one thing, and the top end #'s are fun to throw around. But for me I am looking for that seat of the pants stump pulling grunt, and low end throttle response; that can go right away with too big of a cam. Just a thought. Good luck. -Dale
Old Feb 16, 2005 | 09:43 PM
mshane's Avatar
mshane
Wow that was fast! Thanks a lot. Oh by the way its a 78 bronco, 4" lift, 35" swampers, 4.56 gears.
Old Feb 23, 2005 | 03:17 PM
mshane's Avatar
mshane
Could someone with desktop dyno run these two cams with this set up for me? Thanks.
Old Feb 26, 2005 | 11:25 AM
Dr_j's Avatar
Dr_j
dyno program needs:
Bore x stroke - unless stock
Cylinder head type - wedge, canted or stock
Compression ratio
Induction -CFM and manifold type , i.e. dual plane, single plane, etc....
Exhaust type- manifolds, headers, headers with mufflers etc..
Camshaft type - stock, hi perf, circle etc...or manufacturers number
Lifters - solid, roller, hydraulic
Lift at valve - both intake and exhaust
Dr_j
Old Feb 26, 2005 | 12:24 PM
Homespun91's Avatar
Homespun91
This is with DynoSim (advanced form of DD). Assuming stock bore + .030/stock stroke 460, Edelbrock RPM unported heads with as-delivered valves, & avg. street headers/duals/mufflers:
The Lunati:
2000RPM: 175hp/459lb.-ft.
2500: 223/469
3000: 286/500
3500: 357/536
4000: 424/557
4500: 480/560*
5000: 522/549
5500: 530*/506
6000: 509/445
6500: 441/357
The Comp:
2000RPM: 192hp/504lb.-ft.
2500: 244/512
3000: 307/538
3500: 373/559
4000: 426/560*
4500: 466/544
5000: 484*/508
5500: 454/434
6000: 396/347
6500: 341/275
Should be pretty accurate since I have good, verified flow numbers for the E-brocks and the Stealth.
Old Feb 26, 2005 | 05:00 PM
mshane's Avatar
mshane
Thank you very much Homespun91, I really appreciate it.
Old Feb 26, 2005 | 05:36 PM
Homespun91's Avatar
Homespun91
No prob, I've been working with these two cams, among others, for my own project & had similar combinations already plotted.
If you do the off road thing I'd lean towards the Comp, since your effective gear ratio with the 35"s is not that low, & the Bronco is kinda chubby. Me, I'm actually looking at the Lunati since I have a very traction-limited '55 F-100. And a very stupid right foot.
Any way ya look at it with either cam, that much torque from 2000-6000 is pretty nice.
Old Feb 27, 2005 | 04:12 PM
mshane's Avatar
mshane
Hey Homespun91, I just noticed you are from the Peoria area. I live in Chillicothe. Anyway, I think I'm going to go with comp cam because it has a bit more torque lower in the rpm range and peaks lower also. Going 120 in a bronco is kind of scary.
Old Feb 27, 2005 | 05:04 PM
Homespun91's Avatar
Homespun91
Related to Glen or Garwin Shane, by any chance?
Yep...from Chilli also....small world....
Old Feb 27, 2005 | 10:18 PM
mshane's Avatar
mshane
Yup, they are my uncles.
Old Feb 27, 2005 | 10:23 PM
Powergod's Avatar
Powergod
This is a small world! I am from Ottawa Il and I am trying to figure out what cam to use also. I am just looking for suggestions. I have a pull truck that I want as much power as possible out of it. My mods are MSD ignition, L&L headers to 3" duals, electric fan, bored .060, ported heads on exhaust side, will have 12:1 compession, full roller rockers, Stealth manifold and 1" carb spacer, Demon 850 with mechanical secondaries and 14" K&N, Holley Black electric fuel pump, modified C-6 with 3000 stall. I hope that is everything. If you could help me with some suggestions that would be great. Maybe even some HP numbers. Thanks
Old Feb 27, 2005 | 11:07 PM
Homespun91's Avatar
Homespun91
Powergod,
A couple (actually, a lot) of questions- 1) 429 or 460 based? 2) What axle gearing? 3) 2WD or 4WD? 4) What rpm range or peak are you looking to make power at? 5) What tire limitations, if any? 6) Are you thinking about a roller or a solid cam? 7) I'm guessing this won't see any street time, with 12:1. ? 8) What bottom end mods have you done or are planning on, if any? 9) How's the C6 set up, & do you plan on shifting at all? 10) Got any flow #s on the heads, or what was done to the exhausts, & what castings?
I'm not super versed on pulling trucks (I used to be involved with a modified twin BBC tractor, a whole different animal) but a lot of the pullers I know of, using 33" tires, are turning 7000 rpm plus, and more. That's using some pretty healthy hardware- girdles, four-bolt conversions, filled blocks, and/or sometimes A460 Ford Racing blocks, or Eliminators, if they can get away with it. That's Missouri pulling, though; I don't know much about IL pulling, other than going to the M-P Super Pull in Henry (population. 14, or 15 when the mailman's going through)
Mshane- I'm mentally going through my list of Shanes, trying to figure out which one you might be, or belong to. I graduated from IVC (hanging my head in shame while I type...) in '84, so I'm not too up on the current residents, in spite of still living in the area. By the way, I agree, the Comp should do pretty well.
Old Feb 27, 2005 | 11:32 PM
Powergod's Avatar
Powergod
ok-460, 4.88 gears, 35" tires, 4wd, aprox 6500-7000 rmps's, solid cam, c-6 for pulling, stay in first, no numbers on the heads as far as flow, castings are d3ve, forged crank
Old Feb 28, 2005 | 11:36 AM
mshane's Avatar
mshane
Homespun, My dad is Leon but he graduated in '74 so you might not know him.
