Good luck. 61 thru 66 are same. Don't recall how many rear windows past up during repeated salvage runs. Recently replaced windshield and rubber, thought would do same w/ scratched rear until glass installer advised no longer able to locate. Checked most of ford truck parts suppliers have used in past with no success. Cleaned it up and have treated it with kid gloves since. It has been some time since browsed wrecking yard 65/66 were getting hard to find then. May try ebay. If you find someone in your area who appears to be selling ford truck parts that fit you application you may email them and see if they have a rear window willing to part with. Used that method to get a hood for 65. Suggest tryng the FTE classified, someone may be parting one out. Also check local newspaper classifeid have come across few that were being parted out or being sold for almost nothing. Recently past up change of picking up entire 66 for $500. Rear window almost worth that.
Anyhow, good luck
dave
I have a large rear window from a 63 Unibody and a small rear window from a 63 standard cab that I think will work on a Unibody as well. I am located near Cedar Rapids, IA. Let me know if this helps.
Thanks Tim....I would rather give it away then toss it....guys here have been so immensely helpful over the time I been here...charity begins at home i think....with as much as I have been here...this is a home...in regards to my trucks anyway
BTW...still got my 66 1/2 ton for sale...has to go in next couple weeks.....ad is in classifieds....
