OK, guys, I know there are hundreds of threads on brake bleeding, but, I can't find any that give a conclusive answer, and the Chilton's manual doesn't talk about anything to do with the abs valve in regards to bleeding. I noticed while replacing my master cylinder that there is a bleeder screw on the RABS valve. Do I have to bleed this valve too, and if so, what order so I bleed it in with respect to the wheels, ie. RR, LR, RF, then LF? Where in that order does it go? If that is even the right order? Also, do I have to bench bleed the new cylinder like the old style or not? Thanks in advance guys.
BTW: This is on a '95 2WD F-150
-Nick
<!-- / message -->
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
