Numerous topics
Old Feb 16, 2005 | 02:25 PM
joebrownusmc's Avatar
joebrownusmc
Numerous topics
This is my first post so... Ill try to do my best.
I am currently trying to restore my 1979 F100 Longbed. It currently has a 302 with a Edlebrock intake/carb. I just installed a HEI GM style distrubutor in hopes of getting rid of all the wires i have that are astrue. I also ditched the voltage regulator and the ignition box. I believe the transmission is a C6. (not sure it is or not) Also the rear end is a mystery to me ive searched for the axle code but mine is not listed. Well this is just a little hitory of the truck heres the questions i have.
  • What kind of axle/rearend do i have in my truck?
  • What kind of transmission do i have?
  • How do i set up a one wire distrubutor to the original distributor, alternator, ignition switch, starter solenoid and anything else thats starting related.
  • Im making a custom dash how should i wire toggles to use my headlights, park lights, windshield wipers?
  • Any and all information on my vehicle as well
My vehicles Vin Number is F10GPFB2930
Axle code 11
Type F107
DSO 43
WB 133
Body AB4
Color H
Trans J
-Semper Fi
Joe Brown
Old Feb 16, 2005 | 03:02 PM
F150daniel's Avatar
F150daniel
welcome to FTE.
* What kind of axle/rearend do i have in my truck?
get the codes off the tag on the rear axle.
* What kind of transmission do i have?
Trans codes says C4. is the tranny pan rectangular or does it have a notch out of one corner?
* How do i set up a one wire distributor to the original distributor, alternator, ignition switch, starter solenoid and anything else thats starting related.
* Im making a custom dash how should i wire toggles to use my headlights, park lights, windshield wipers?
get a Haynes manual it has a wiring diagram in the back.
* Any and all information on my vehicle as well
build sheet from ford.
To find your build sheet there are numerous places it could be:
Under the seat
Under the carpet
or
Take the headliner down and feel around up in there
Old Feb 16, 2005 | 05:20 PM
Mil1ion's Avatar
Mil1ion
WElcome to the site.
We have a couple of READ FIRST: threads attached to the top of this forum.
Can I get you to read them especially Post #1 in this thread ?
https://www.ford-trucks.com/forums/s...d.php?t=102632
