Oil
Old Feb 16, 2005 | 01:01 PM
six6plymouth's Avatar
six6plymouth
Oil
what is the correct wt. of oil for the transfer case.
Old Feb 16, 2005 | 05:29 PM
Mil1ion's Avatar
Mil1ion
THis question is NOT a 73-79 specific question, it is about The transfer case which is used on MANY other year trucks.
Thread moved to Drive-train forum,where the answer has already be posted.
Old Feb 16, 2005 | 08:49 PM
SoCalDesertRider's Avatar
SoCalDesertRider
What oil you need depends on what transfer case you have. If you have a part-time gear-drive iron-case NP205, it uses gear oil. 90wt will do fine. Other iron gear-drive cases, like the Dana 20, 21, and 24 t-cases, also use gear oil. The NP203 iron full-time chain-drive t-case uses 10-40 motor oil, if I remember correctly (been a few years since I had an NP203). Most later model aluminum chain drive t-cases use tranny fluid.
