460 swap, need engine towers
Old Feb 15, 2005 | 11:42 PM
shadow44_z's Avatar
shadow44_z
Unhappy 460 swap, need engine towers
hi everyone, im new to this site and excited to be here now. wondering if anyone can help. i have a 74 ford f-250 high boy 4x4. im putting a 460/c6 in it and am having a problem finding motor mounts. if anyone can give some insight in to what to do i would greately appreciated.
thanks
shadow44_z
Old Feb 16, 2005 | 11:24 AM
fordfury469's Avatar
fordfury469
go to l&l products they have all the stuff youll need.
Old Feb 16, 2005 | 09:23 PM
shadow44_z's Avatar
shadow44_z
thanks for the info
shadow44_z
Old Feb 16, 2005 | 11:38 PM
tractor_man83's Avatar
tractor_man83
try autofab com not cheap but built tough like the factory 2 wheel mounts that cross the bolts so that it wont pull apart like the rubber will while still absorbing the vibrations
Old Feb 23, 2005 | 06:40 PM
poorfolks's Avatar
poorfolks
I put a 460 in my 78 f-150 4x4 with no aftermarket parts. I used a set of 360/390 motor mounts turned so 2 holes lined up with the 460 motor mount holes. Then I cut out the face of the towers and took a piece of 1/4" steel plate and remade the face with the notch for the motor mount stud moved forward about a half of an inch and rewelded it to the tower.
Worked fine and was CHEAP.
shadow_almanza
Jan 10, 2011 05:01 AM
emd160
2004 - 2008 F150
Jul 10, 2006 08:18 PM
shadow44_z
Mar 3, 2005 09:18 PM
grevalaz
All Things Towing
Jul 26, 2003 01:49 AM
hood
Paint & Bodywork
Jan 30, 2003 08:09 PM
