I have a 93 aerostar with 136k mi 3.0 v6 at start-up it will idle up and down probably 15-30 times pe min, then after it warms up it runs fine. sometimes it will quit and start up again if the van is not 100% warm. any ideas?
Sounds like your IAC valve. If you don't know what it is or what it looks like, it has a two wire connector attached to it and is held down by two small screws/bolts. It sits on the top of your engine and can easily be replaced by even the mechanically challenged. Ford engines have been notorious for having these go bad. If this is the problem, get one from Ford or a good aftermarket store.
Try rapping on the MASS air sensor when it is idling and if it smooths down, it my need replacing. The Ford shop here in town showed me this, and he was right.
I would also say it is the IAC valve is the most likely suspect. Also how old are your plugs and wires? And before replacing the MAF, I would try cleaning it with some electrical cleaner before replacing.
The IAC (or Air Bypass Valve) Is ridiculously easy to remove, clean, and put back on. Two screws, thing comes off. I cleaned mine by blowing out the loose build up with the air gun, spraying the crap out of it with a silicone basaed lube and letting it soak for a while, then blowing it dry with the air gun again. Also, the little black cap on the side is not just a cap, it allows air in and has a built in filter. make sure you clean it out too.
After you replace the IAC, you should give a bit of a turn to the throttle cable adjusting screw It is right by the IAC under that black plastic cover. The cable from the gas pedal comes in and is attached to a springed lever. there is a screw that sets the stop position. You should give the screw a turn so that it slightly increases your throttle rest position.
These two things will make the problem go away. At some point you may still need to buy a new IAC.
