Bodyside molding?
Old Feb 15, 2005 | 06:38 PM
johndeerefarmer's Avatar
johndeerefarmer
Bodyside molding?
Do I want it or not? Does it detract from the look? Does it prevent dings?
What's your opinion?
Old Feb 15, 2005 | 08:32 PM
jrz1's Avatar
jrz1
I ordered it on a solid white F250 CC LB. Think it helps break up the sheet metal a little aside from protecting against door dings.
Old Feb 15, 2005 | 08:50 PM
huntercgr's Avatar
huntercgr
Does not detract from the look and it will prevent some door dings. Get it.
Old Feb 15, 2005 | 09:47 PM
Wrenchtraveller's Avatar
Wrenchtraveller
On True blue it is hard to see but gives protection. Wrench
Old Feb 16, 2005 | 04:50 AM
captchas's Avatar
captchas
Guest
i have to back up wrench as mine is also true blue, my garage is tight and will be a little tighter so the other half some times hits the side with her door it helps abit.
Old Feb 16, 2005 | 06:26 AM
Noonan's Avatar
Noonan
Like others have stated, it doesn't stand out since its the same color as the truck. In my case, it's Dark Stone over Arizona Beige and the BSM blends in. When I picked up my truck, I had to do a double-take to see it. On my 88 it stands out prominently, probably because it's about three times as big and black rubber.
Old Feb 17, 2005 | 06:44 PM
captchas's Avatar
captchas
Guest
i only look at it as i could not buy them for the price and they do help a little, same for the factory black rubber floor mats i can't buy them for $25.00 for front and rear, its a personal choice thing.
