500 cfm 4bbl on a 390?
Hi All,
I have a Carter 4bbl carb (appears to be exactly like a Edelbrock Performer) that I have "borrowed" off another rig of mine thats parked permanently to run on my rebuilt 390. The carb has very low miles since new, so I'm hoping I don't need to go buy a new one.
Anway, I checked the #'s on it and it appears to be only rated at 500 cfm. I was thinking it was bigger because it was originally purchased as a replacement on a '77 Lincoln with a 460. Would 500 cfm be a stock 4bbl replacement for a 460? Seems awful small for that big of motor.
Just wondering how poorly a 500 cfm will do on this 390? Running a 901 cam, 9:1 compression, Edelbrock Performer (not rpm) intake and headers. If it's a big power difference I'll bite the bullet and goto a 650cfm but thought I would run it by you guys.
Jordan
Jordan
What are the numbers on your carb?
I have a carter that I picked up from a guy and was trying to find out the CFM but haven't had any luck.
I am assuming it is a 500 because the butterflies are slightly smaller than my Holley 600.
Is there a reference on any website I could go to?
Thanks, Ken
Thanks, Ken
Funny you should ask, seems like finding carter performer carb info on the net is a bit tough. I'm not sure if they're not making them anymore (Edelbrock performers only now) or what.
The # on my carb, located at the lower left was 9504S. Best I can figure is that it's the same as the s-9504 listed on this page;
http://www.carburetion.com/after.htm
Jordan
Jordan
beeturbo
12-29-2022 08:53 PM
ratwell
17
11-14-2002 02:19 PM
