Aerostar Ford Aerostar
Help on 93 aerostar
Old Feb 15, 2005 | 02:44 PM
Eric334's Avatar
Eric334
Help on 93 aerostar
Hello all, Long time reader, 2nd time poster.
I got a 93 Aerostar and well the problem is when you apply the brake the right turn signal lights up, on the dash and out at front and back lights. If the right turn signal is flashing and you apply the brake it stops flashing and just lights up.. Any answer? I have check both the rear and front marker light and the bulbs seem to be ok, neither are burned out.. Please help.
Old Feb 15, 2005 | 06:49 PM
himthere's Avatar
himthere
Check ALL the bulbs, keying on the right side. Side marker, front and rear. If all are good, check the sockets they fit into, then the wiring. Sounds like a short circuit to me. The tough part is locating it.
Old Feb 15, 2005 | 06:56 PM
Kruse's Avatar
Kruse
Before you do any more troubleshooting, go buy you a couple of brake light bulbs and replace them. In a dual filament bulb, sometimes one will break and jump to the other filament. Both filaments will then light up, but will bleed back current into the other circuit.
If that doesn't fix your problem, then it is time to do your troubleshooting.
Old Feb 15, 2005 | 07:16 PM
93nighthawk's Avatar
93nighthawk
I agree, just replace the bulbs. They don't last forever....
Old Feb 15, 2005 | 09:30 PM
agelder's Avatar
agelder
H/L switch has burned it's harness, replace both.
Old Feb 16, 2005 | 12:57 PM
Eric334's Avatar
Eric334
Tried replaceing the bulbs, No go.
What is the H/L switch and where is it?
By the way, Thanks guys, didn't want you thinking I don't appreciate the help.
Old Feb 16, 2005 | 02:17 PM
Bear River's Avatar
Bear River
Former ******
The Headlight switch is the **** on the left side of the dash. You know, the one that you pull to turn the headlights on and off. I'm pretty sure all the major lighting goes through it. They have a history of melting and burning. If it has melted,it could be shorting.
Old Feb 16, 2005 | 02:31 PM
Eric334's Avatar
Eric334
I was kind of thinking that is what he ment by H/L switch, but I wasn't for sure.
thanks
Old Feb 16, 2005 | 02:35 PM
Torsen Rick's Avatar
Torsen Rick
If Ford wired the switch in these vans like they have in other cars of the same time, then all of the current to lamps flows from the power source, through the switch and then out to the lamps rather then using a relay to handle it. The switch actually directly controls the hot current going to the lights. This tends to be hard on the switch itself and it has negative side effects on light output because of the voltage drop that occurs through the switch and all of the wiring required to run from the battery to the dash and then back to the front of the van again.
I've had to replace headlight switches in several vehicle because they burn out because of this. I've also rewired most of my older vehicles to use a relay to control the power to the lights, which makes the dash switch a sort of remote controller. I'll probably do the same thing with my van when I get the chance so I can run higher wattage bulbs without risk of damaging the harness or the switch...
Old Feb 16, 2005 | 04:32 PM
Eric334's Avatar
Eric334
Tried a new Headlight switch and its a no go. Still have the problem. Man this is not going to be fun to find the problem
Old Feb 16, 2005 | 06:03 PM
JTHill24's Avatar
JTHill24
Eric334:
If it was me....I'd look at the Brake Light Switch on the Brake Pedal or for a pinched/cut wire shorting out when the pedal is pushed.
Jay
Old Feb 16, 2005 | 10:12 PM
tom_foreman's Avatar
tom_foreman
Without looking at the wiring diagram I'd say you have an open ground. Check to see of the ground pin in the bulb socket has continuity to ground.
If you loose ground with the dual filament bulb the power will go through the brake light back up the turn signal line. That is why the turn indicator in the dash lights up.
With the turn signal on and the brake light on you have power at both side so you get nothing.
Anyway this is without looking at the diagram. Check both the front and rear lights on the right side.
