Sponsored by: Kumho
whining steering pump
Old Feb 15, 2005 | 07:45 AM
frenchf250's Avatar
frenchf250
My pump is whinning in my 90 f250 4x4, and my fluid is lowering I have to keep adding some. Where can it go?
Old Feb 15, 2005 | 08:29 AM
Thomasm67's Avatar
Thomasm67
You probly have a leak somewhere in your lines. Take some time and wipe your power steering pump and lines off with a rag then rune your engine and place some paper towels under the front part of your engine if it is leaking you'll get a good idea where it is.
Old Feb 16, 2005 | 01:52 PM
mrsuperman15's Avatar
mrsuperman15
might also try this it worked for me, have someone sit in the truck, engine running, pop the hood have the person inside turn the wheel, you should be able to see the fluid coming out from somewhere (hopefully you're leak isn't this bad yet)
