I bought some today, just because it had a $ back if not satisfied, ($15.00) WOW I waxed my Screw in less than an hour, this wax does everything it says as far as application, we will see how long it lasts, no dust, easy on easy off, just can't believe how good this is, hope I posted in the right place
that wax is great stuff. i waxed my truck with it back about the end of summer and it still shines like after i waxed it. it lasts alot longer than the gold class wax. yes, the wax goes on really easy and comes off really easy, it is the best i have used so far.
I love it. I've been cleaning,polishing, and then using that on my Mustang. It does an awesome job. I used it the last time I waxed it too. It really holds up, as long as you wash your car/truck with car wash soap and not dish soap.
i actually was my truck with johnson and johnson baby shampoo no tears formula. the reason a wax job gets took off of you car or truck is because of an acid the the car wash to help get it clean same with shampoo and the no tears formula does not have that acid in it. try it out, your wax job will last alot longer.
never thought about the acid content, I use meguiers car wash soap
Anyone know if there is any acid in the meguiar's line of car wash soap?? Or any other brands for that matter which don't contain acid or other things which strip wax??? --Thankx
I have been using meguiars stuff for quite a while now and am very pleased. The NXT concentrate car wash does not strip wax. Says right on the back "non-detergent formula wont strip off wax protection". Also says that it has water softner in it.
Like others stated, meguiars NXT wax is good stuff. I used the Meguiars Gold Class before and it was OK but not as good as NXT. I consider waxing an on going project and I am continuing waxing. Kind of therapy for me. And the bottle lasts and lasts. Only issue is that it does whiten the plastic. Can't have everything.
I've never used meguiars products, but have good luck with Amsol polish for clear coat paint - easy on and off and what I really like about it is you don't have to be real careful with the black rubber molding and trim wipes right off . Only problem is you have to find a distributor in the area.
