What does the 1.15ar, .84ar, and so on represent? I have kind of guessed that the bigger the number the bigger the flow, but what does the number represent?
Your exhaust housing has two holes in it... an entrance point and and exit point. These are the A and R values. A being the exit area of the turbo housing, and R being the scroll radius - or basically the entrance area for the turbo housing.
1. If the a/r is less than 1.0, the intake hole is larger. Which means in addition to extracing the exhaust's energy, it also accelerates the exhaust flow....so it spools very quickly at the cost of increased backpressure. If the a/r is larger than 1.0, the outlet is the larger hole. Supports increased flow with lower backpressure, but takes longer to get on speed = turbo lag.
2. Yes. Like in the case of the van turbo. The intake housing, compressor wheel, bearings, etc. are the exact same parts found in a stock truck turbo.
3. Yep, though I think all the stock or stock replacement PSD turbo's use a 1.0 intake.
I went out and looked at my turbo after reading this thread. Mine says 1.10 A/R. I've heard you guys talk about 1.15 A/R and .84 A/R. I guess I don't fully understand the difference. What does this mean on mine? It is a Garrett.
