timing chain
Old Feb 5, 2002 | 10:23 PM
porkchop's Avatar
porkchop
timing chain
I have an 85 with a 302fi.I will be changing out the timing gear WITHIN THE NEXT FEW DAYS has anyone every used a Dual idler gear and would it be better in the long run? instead of the standard timing chain set replacment parts
any help??/
Old Feb 6, 2002 | 12:24 AM
Franklin2's Avatar
Franklin2
timing chain
Never used one, but it's for racing and overkill to put it on a regular daily driven engine. Most people buy them with the straight gears so their engine will make a whining noise. You can't go wrong with the factory set-up, except don't use the plastic coated top gear. A double roller timing chain set-up would be a nice upgrade.
Old Feb 6, 2002 | 08:20 AM
porkchop's Avatar
porkchop
timing chain
Thanks for the info... I will go to a double roller and as for the whining noise I have kids that make enough of that I don't need my truck doing the same .
Old Feb 6, 2002 | 04:01 PM
canadianfordman's Avatar
canadianfordman
timing chain
