V 8 swap?
Old Feb 14, 2005 | 02:06 PM
jvs1010's Avatar
jvs1010
V 8 swap?
Hello all, I'm new here, just a quick question, will a 1989 ford econoline 5.0 efi
fit 1986 f150 5.0 efi, if so what if any problems or changes would be needed.
Old Feb 14, 2005 | 02:13 PM
ronclark's Avatar
ronclark
Should bolt right in although the dipstick for the oil will be different and you will probably need to swap over. Not sure if the 89 has the serpentine belt system with the reverse water pump, if so you may need to make sure you use the complete belt water pump system one way or the other.
Old Feb 14, 2005 | 02:15 PM
jvs1010's Avatar
jvs1010
thank you very much
